Diesel does not start motor with Cammon Rail
15 years 8 months before - 15 years 8 months before #12715 by manual-mecanica
Manual-mechanics response on the topic Re: Diesel engine with common rail won't start
Do common rail engines have glow plugs? I had that kind of problem with a diesel without a common rail, and that was it. Another thing you should have checked is the starter motor; maybe the engine isn't turning over. Regards...
Latest edition: 15 years 8 months before by .
15 years 8 months before #12754 by manual-mecanica
That's right, I forgot to mention the vehicle model; it's a Hyundai Terracan 2.9 CRDi Diesel. I don't remember the mileage.
For now, I'll try it with the information you've given me. I look forward to more comments with the details I've added.
Thanks
15 years 8 months before #12762 by manual-mecanica
The diesel fuel rail before the injectors has a sensor at the end. I disconnect it, blow it out with compressed air, and it starts more easily. If I disconnect the return lines, is the injector flow check done at idle or at high speed?
