Nissan Xtrail Turbo Diesel
15 years 6 months before #12585 by manual-mecanica
Nissan Xtrail Turbo Diesel published by Manual-Mecanica
Good morning,
I have a problem with my Xtrail 2005. It presents two failures: one is lack of strength as if it did not activate the turbo and another is vibration when it is in neutral run as if it were working in 3 cylinders. They reviewed the injectors and they were all fine.
A workshop told me that I had to lower the machine and make an overhaul.
As this does not cost two reais with other opinions.
It tells me a Nissan mechanic that the failure can be in the steering wheel, since it has indicators that are read by a sensor and they send information to the injection of the vehicle.
It is my first experience with a Diesel Turbo car
15 years 6 months before #12600 by manual-mecanica
Manual-Mecanica Answer on the Re: Nissan Xtrail Turbo Diesel
I do not think it is what they tell you if it seems to be in three cylinders, the most caused thing is that this is the problem the injectors are only a part, I substantiate it as Czech the compression of the cylinders, so you tell me one of them must be very low. let us know.
15 years 6 months before #12624 by manual-mecanica
He was done a compression test and the values ​​were within the range according to the agency. The car lights perfectly being cold or hot.
The injectors are advisable to clean them or is it better to replace them?
15 years 6 months before #12648 by manual-mecanica
They can be cleaned and in some cases stressed
15 years 6 months before #12654 by manual-mecanica
Do you get any failure?
