ELECTRICO ELECTRICO PEUGEOT 306
18 years 8 months before #1252 by manual-mecanica
ELECTRICO ELECTRICO PEUGEOT 306 Published by Manual-Mecanica
Hello friends of the forum. I have the following problem:
in a 306 turbodiesel of 96, the windows of the co -pilot door only descend with the control of that door, with the driver's door command or go up.
I have disassembled the door and proven that the motor fondles correctly, revolves in both directions according to the polarity with which it is feed.
I have also checked the buttons and are correct.
If someone can give me a solution, I would appreciate it. Greetings.
18 years 8 months before #1256 by manual-mecanica
Manual-Mecanica Response on the Re: Electric Electric Curs Peugeot 306
Have you disassembled a door that works well?
What did you expect to find?
a goblin?
Let's see your left hand hurts and we operate the dercha?
You have said it yourself, with the button of your door does not work and with the other if
you guess which one has the problem ......
yes !!!!! correct the button of your door fails.
Pd made the interventions of Megabeat, possessing all technical explanations (why and how).
18 years 4 months before #1459 by manual-mecanica
Manual-Mecanica Answer on the subject Hello
Hello friend, according to you say the driver's side key it works well? How do you know? Try to clean it with a clean contacts inside it or replace it with a new one, surely that is the problem, unless a cut cable, which occurs very frequently in the wiring that is between the door and the parante, greetings and I hope that solutions
are still the next principle ... If something is not even touched
