Mitsubishi Montero
15 years 9 months before #12288 by manual-mecanica
Mitsubishi Montero. Published by manual-mecanica
Help! I have a 1999 Mitsubishi Montero 2.8L turbo intercooler diesel. When I start it in the morning (it's freezing cold), it starts right up, but after 20 or 30 seconds the engine starts to misfire until it stalls. When I try to start it again, it's very difficult, and when it does start, it emits a lot of smoke from the exhaust. I have to keep it at 2800 or 3000 RPM to prevent it from stalling. Once it warms up, it runs fine.
I would appreciate your advice. Thanks.
15 years 9 months before - 15 years 9 months before #12291 by manual-mecanica
Manual-mechanics response on the topic Re: Mitsubishi Montero
Well, my dear friend, what you need to check in these cases is the fuel pump and the injectors, since these often fail. In the case of the pump, it could be out of phase, and if the injectors are dirty, make sure they're working properly. Also, if it has glow plugs, try replacing them, depending on your model.
Last edition: 15 years 9 months before by .
15 years 9 months before #12319 by manual-mecanica
The injection pump has worn seals.
You need to replace the gasket and seal kit; it costs approximately 300 euros.
15 years 8 months before #12337 by manual-mecanica
Hi, as others have already mentioned, check the glow plugs. I also recommend checking the fuel system for air leaks, water in the filter element, and any other leaks. Cheers!
15 years 8 months before #12805 by manual-mecanica
Hi...how did it go with your Montero?...I've had the same problem for a few days now...greetings.
