Tracker 98 ignition
15 years 7 months before #12279 by manual-mecanica
98 tracker ignition published by Manual-Mecanica
Hello .. I have a geo tracker 98 with the problem that the transmission of the engine has been separated while in use. The above falling into a hole on the track. The main fault has been repaired. The problem now is that it does not turn on .. it goes when turning the key but the pulleys and the engine do not turn ... being neutral. The pulleys turn them manually moving what it rules out that it is diverted ..
Any idea of ​​what is the problem?
Thanks and greetings: Cheer: since Queretaro Mexico
15 years 7 months before #12290 by manual-mecanica
Manual-Mecanica Response on the Re: Lighting Tracker 98
It is strange because if it moves by hand, there would be no problem when turning it with the starting may that it happened is that the start or that some key is ground, it is ground, it will take the start first to see what happens and then check the cracks of the camshaft and the crankshaft.
15 years 7 months before #12305 by manual-mecanica
What you have to do is kitar the transmission and give it to the start. And you will see how you find the problem that you do not start and that you have broken your transmission because of the group.
