Peugeot 1007 starter engine
15 years 7 months before #12258 by manual-mecanica
Peugeot 1007 starter engine published by Manual-Mecanica
I have problems in the starter engine of a Peugeot 1007. Where is this and how can I disassemble it? THANK YOU
15 years 7 months before #12270 by manual-mecanica
Manual-Mecanica response on the Re: Peugeot 1007 starter engine
The start is lodged between the Bloke and its other outlet is inserted inside the gearbox, it fits the steering wheel, it can be in two places under the multiple of admission or under the exhaust multiple. They carry two or three bolts and two or three cables, remember to disconnect the battery before and Hojo that in Peugeot it can happen that when the battery disconnect, the airback light is turned on from the airback do not scare yourself if this happens.
