Non-Larga Alternator Alarm in Opel Monterey
15 years 7 months before #12204 by manual-mecanica
Non-Large Alternator Alarm in Opel Monterey published by Manual-Mecanica
Good, I have recently changed the alternator to an Opel Monterey (Isuzu 4GJ2 engine) and alarms (signaling lamps in the box) of no battery load and others are not reset (or replenish).
The new alternator loads correctly, ... Any idea?
Thank you
15 years 7 months before #12231 by manual-mecanica
Czech first than all cables are connected if everything is okay can see a problem in the connections of the alternator output that is the one that sends the signal to the board can be invested the fields, the fields, the fields,
15 years 7 months before #12247 by manual-mecanica
The first thing is to check the fuses should take a loading one then treats this the alternator's pineapple, put ignition, check if the battery light is still touched, it should not be, then with a current tester, in the alternator's pineapple, a line must arrive at a line that when putting the tester in negative, earth, or chassis does not know what you will call you should mark the battery light. Battery or perhaps ignition If that will possibly pass the integrated regulator is failing by the regulator has two functions one is to load the 14.5 VLTS KE needs the system and the other is to turn off the battery light.
Please answer how it went with your problem
