Help with Hyundai Verna Gl 1.5 from Mexico
15 years 7 months before #12166 by manual-mecanica
Help with Hyundai Verna gl 1.5 of Mexico published by Manual-Mecanica
Hello, I am from Mexico, I have a Verna 2005 1.5 GL, and I am having a problem to see if you know the case and you can help me, it turns out that today in the morning when you start my verna after all night off, the car sounds the divers, it is a question of 5 seconds more or less, as it takes to load, I have the doubt that some diver is bad or the oil pump is losing power? or is the oil simply dirty? Although he has three months to change it, thanks for his help
15 years 7 months before #12176 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with Hyundai Verna Gl 1.5 of Mexico
It can be downloading the taquis is normal you change and now, but as they are a bit expensive until you do more and fix it.
15 years 7 months before #12195 by manual-mecanica
hello; In some cases this is corrected using a lower oil viscosity. If it is usually 20W50; You can replace it with a 15W40 or 15W50, also keep in mind if there are no sediments inside the engine; This is corrected by making a fluchin or internal motor washing with specific products for this case; However, I have done it with an ACPM or diesel pint, at the time of making oil change. It is applied by the filling cover, the engine is allowed to work. 15 minutes, and then the oil is drained, replace the oil filter and place everything new.
good luck
