Problems with Mazda Allegro Motor 1.6 year 2000
15 years 7 months before #12160 by manual-mecanica
Greetings
I turn to this forum looking for a little help regarding a problem that I have with the car.
He has a strange sound, which could possibly be the bearings it turned out that they were well, then they recommended to change the axis tip of the tripoid and I did it, however the spare was not the original because there is no and place one of the Ford lance or leicer (the siege is almost the same) however they gave it to me and sounds feast as two dishes rose and turn the steering wheel and turns completely when it only turns and turns it.
Please, I would be grateful if someone helps me with a PSO solution in the consent is charisimooooo all
thanks
15 years 7 months before #12196 by manual-mecanica
Please specify the noise is underway, or when braking, if you already inspected the brake pasta, if there is a corresponding rotation of tires, alignment address and balancing tire. Greetings. DODE DINS THIS SURVISE.
