Nissan Micra does not stop
15 years 7 months before #12228 by manual-mecanica
Manual-Mecanica response on the Re: Nissan Micra
The steering wheel is not, but it will be necessary to disassemble the plastic that cover the steering wheel both below, the test lamp is a tool that is usually done and not bought, it connects to negative with the pinion and the tip closes the circuit, and turns on the lus, then you look Which does not cut the current, if we are all well looking for another solution.
