Problems with Chevrolet S10
15 years 7 months before - 15 years 7 months before #12126 by manual-mecanica
Problems with Chevrolet S10 published by Manual-Mecanica
Hello to everything, I tell you that I have a Chevrolet S10 year 1998 2.2lt. It turns out that I need to change the thrust bearing of the gearbox. The problem is that I do not have to disassemble because I do not know how to disconnect the cabole that goes from the hydraulic pump to the box. My query is to know how I can get that piece since I have tried everything.
Thank you very much
PS: If someone has the workshop manual of this truck model please publish it in the forum.
thank you so much
Very good forum
Last edition: 15 years 7 months before by .
15 years 7 months before #12165 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Chevrolet S10
Is that the hose that goes from the hydraulic pump to the bearing right? If this feet has insurance that is complicated to get if you do not have the necessary tool, since it has a kind of clip, you have some moving moons put them in the couplet, undeles a little and then pull them out outside it is complicated but with patience you achieve it.
