RAV4 2001,2002,2003,2004 with immobilizer?
12 years 11 months before #39749 by manual-mecanica
Manual-Mecanica response on the subject ¿RAV4 2001,2002,2003,2004 with immobilizer?
Excellent contribution I just saw it will help me that invention I have a problem with an isuzu man year 2000
12 years 11 months before #39750 by manual-mecanica
Hello brother if your car turns on for two seconds and then turns off and Keda the Light of Security on the board if it is a problem of programming responds to help you
12 years 11 months before #39764 by manual-mecanica
they unlocked it from the computer and then took the fuse since now the immobilizer is eliminated, the truck started as if I had never had problems at the first It is like the slowdown is low, the slowdown told me to clean the flow it will be possible that with that the truck will be ready.
12 years 11 months before #39771 by manual-mecanica
Ok I read you yesterday but the Internet left the manual that I got from the driver, I scanned it with the actr CP 9185 which gave me communication error then revised all the fuses and nothing was checked Light I do not know if this vehicle brings any module or will be the immov that is my dilemma, take the ECU to review it on Tuesday or tell me if it is bad but it is almost the immov because with that bridge it turns on tries to translate the manual but I do not understand it well here this
passlock
your vehicle is equipment with the passLock
Theft-deterren System.
Passlock is a passive theft-deterrent system. Passlock enables fuel if the ignition lock cylinder is Turned with a Valid Key. If a correct key is not used or the ignition lock cylinder is tampered with, fuel is disable.
During Normal Operation, The Security Light Will Go off approximately five seconds after the key is Turned to the run ignition position.
If the Engine Stalls and the Security Light Flashes, Wait about 10 minutes unni the light stop flashing Before Trying to Restart the Engine. Remember to Release The Key from The Start As Soon the Engine Starts.
If the Engine Does Not Start After Three (3) Tries, The Vehicle Needs Servise.
If the Engine is running and the security light comes on, you will be uble to substart the engine if you turn the Engine Off. However, You PassLocksystem is not working properly and must be Serviced by Your Dealer. Your vehicle is not protect by passLock at This Time.you May Also Want To Check The Fuse (see “Fuses and Circuit Breakers” in the Index). See Your Dealer for Service.
By the way correct me if this issue is not here for being from Isuzu or tell me how to open another post thanks
10 years 6 months before #49310 by manual-mecanica
Mr. Molina, good afternoon. Looking to find his video and it is exactly the problem I have with two RAV4 a 2003 model and a 2007. They did not want to start after the battery disconnected to load it. I would like to ask if there is any order to connect and disconnect the white plugs of the ECU or is randomly. Try to do it up to 9 times but it hasn't worked yet.
I appreciate your support. Happy afternoon
