Porblema solar roof
18 years 8 months before #1203 by manual-mecanica
Porblema solar roof published by manual-mecanica
I would like to know what are the possible reasons for a sunroof to stop working. And if it is a fuse, if someone could tell me what is the sunroof fuse in a Peugeot 206 GTI, since I do not have manual. Thank you so much.
18 years 8 months before #1209 by manual-mecanica
Manual-Mecanica response on the Re: Porblema solar roof
I am going to ask a colleague of mine who works in Peugeot, anyway, in the car's instruction book, section "Fuses, replace Escocharra !!!
18 years 8 months before #1225 by manual-mecanica
Pay attention to this parish encyclopedia of the car that is Megabeat, with all the reason in the world has advised you which motor workshop would have wanted to give you long so as not to fix the Peugeot.
Reading the User Manual is important
18 years 8 months before #1233 by manual-mecanica
Hello.
I would look at the fuses first, as others say.
Then I would check the button with a canter.
The next step is to see if it comes positive and dough.
If all this is fine, put direct tension to the engine, and if it works, it is clear since it is a cable between the button and the engine.
I hope I get on time and serve you.
SALU2
SOB
EDITO: If the sunroof is not of origin, it is most likely that some "spabilao" has taken feeding from the inner ceiling. In this case, it is possible that the inner light fuse is possible, or the roof itself, which is usually in the button of the button.
