Acceleration problems Dodge Neon 2000
15 years 7 months before #12009 by manual-mecanica
Acceleration problems Dodge Neon 2000 Published by Manual-Mecanica
I have the problem that the engine has many acceleration changes simply accelerates a lot and so it is maintained, it is composed when I turn it off and turn it on but soon, it will be the same, will it be a heating problem? What happens is that the radiator fan did not enter and what I did was put it directly and remove the relief and fuse of the fan
15 years 7 months before #12055 by manual-mecanica
Manual-Mecanica Response on the Re: Acceleration Problems Dodge Neon 2000
I believe that you should check the water system and purge it, that it does not have air, the second check the operation of the temperature sensor.
15 years 7 months before #12113 by manual-mecanica
Good I think you should check the TPS.
15 years 7 months before #12119 by manual-mecanica
Czech that there are no broken empty hoses. See if disconnecting the MAF sensor the engine is better. If so clean the sensor with freo cleaner and very careful.
15 years 7 months before #12120 by manual-mecanica
Well, apparently the problem was that the air filter was covered, when I remove it, I will improve it but I will continue trying it
