problem with my American quantum
15 years 7 months before #11970 by manual-mecanica
Problem with my American quantum published by Manual-Mecanica
Friends someone m can help on my VW quantum since it wets too much two spark plugs to stop the engine due to gasoline accumulation has the Bosch-K-Jetronic injection system direct injection to 5 cylinders if you know where to get the manual to gauge it or if someone who proceeds in these cases
: Dry: their friend SCOT 02
15 years 7 months before #12029 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with my American quantum
Friend The Ktronic system is a bit complex, if you can communicate with megababat_1 he knows well is system, now the calibration of the injectors cannot be Cylinder is changed together with the injector then this is the problem, if the problem followed and wet the same spark plugs is already a comprehensive motor problem or something tests and let us know.
