Problems with Daewoo Lanos 2000 Venezuela
15 years 8 months before #11856 by manual-mecanica
Problems with Daewoo Lanos 2000 Venezuela published by Manual-Mecanica
Who helps me with my Lanos Daewoo year 2000, I have problems, I turn it on and stay a few minutes very stable, then fail and turn off, they told me that I changed the map sensor when the Scaner passed, I bought a new one and continue with the fault ... I even enchba the gasoline spark plugs, please if anyone knows about the solution would be appreciated
15 years 8 months before #11861 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Daewoo Lanos 2000 Venezuela
In my opinion it could be, the engine sensor of the motor or also some negative, which is disconnected or sulfatado .. normally the set of negatives under the coil and a little more in the direction of the servo brake
