as is known when an ignition coil
15 years 8 months before #11844 by manual-mecanica
as is known when an ignition coil published by Manual-Mecanica
How is it known when an ignition coil is bad, ????
15 years 8 months before #11852 by manual-mecanica
Manual-Mecanica response on the Re: as is known when an ignition coil
You place a spark plug at the exit of the coil connected to the car and make dough with the spark plug if it produces a violet spark and strong the coil is good if on the contrary the spark is yellowish and weakened or there is no spark the coil is bad ;)
15 years 8 months before #11942 by manual-mecanica
It depends on the problem, it may not be current to the coil or that it is an intermittent failure as in Renault Clio II
