Renault Clio problem
15 years 8 months before #11822 by manual-mecanica
RENAULT CLIO PROBLEM PUBLISHED BY MANUAL-MANICA
Good morning,
I have a Renault Clio 1.9 D, from 1999. The problem I have is that I have observed that a right cable has been released where the left front wheel is and I don't know what it can be. Maybe some sneak of something? If anyone knew it can be? Thank you
15 years 8 months before #11837 by manual-mecanica
Manual-Mecanica Answer on the RE: RENAUL CLIO PROBLEM
Hello friend, most likely it is the cable of the wear sensor of the brake pads that sometimes usually check it well, luck and greetings. : Cheer:
