RENAULT CLIO/PLATINA FAILURE
15 years 8 months before #11785 by manual-mecanica
RENAULT CLIO/PLAINA FAILURE PUBLISHED BY MANUAL-MECANICA
Hello good night, I have a Renault Clio Mod 2005 in the workshop, it does not start, the crankshaft sensor is already changed and it remains the same. Tests were done to see if the sensor detects the rotation of the pulley and if it gives me the signal, but I connect the scanner and enter the data line and do not record the RPM, I do not have fault codes, I already changed from ECU and the body including the key and also check them in another vehicle and everyone is working correctly. The immobilizer system is also checo and is working properly. I appreciate the forum's opinions in advance. thank you
15 years 8 months before #11797 by manual-mecanica
Manual-Mecanica Response on the Reeult Clio/Platina Failure
How, according to what you have you have not reviewed the main systems that are ignition and injection, if the system of the computer recovers positive energy and the negative to Maza in chassis an observation reviews if it does not have a secondary system of silent immobilisator. I await your answer and comment.
By chance you will have the awake scheme of the Easyyronic Corsa Chevrolet box.
15 years 8 months before #11807 by manual-mecanica
Good morning, all these tests have already been performed, the impedance of the coils and that of the injutors were cool and they are ok, the dirt pulsations of coil are not, there is no, that of the injection gives me two pulsations and it is cut, apparently I have a failure of the immobilizer. But it already has another ECU, BCM and key. And it is still the same
15 years 8 months before #11826 by manual-mecanica
Greetings, let's go from the beginning before all I failed or it was sudden. On the other hand, the relationship of the distribution band may be run or broken. This can cause you not to have combustion in the cameras due to valve creeps.
15 years 7 months before #12132 by manual-mecanica
Good evening, the time band relationship is checked and the machine has good compression. The scanner does not mark the fault. thank you
