Motor Sicronization 4.0 SOHC of Ford Explorer
15 years 9 months before #11746 by manual-mecanica
Motor Sicronization 4.0 SOHC of Ford Explorer published by Manual-Mecanica
Good afternoon:
if they could help me with the synchronization of the distribution system of a 4.0 SOHC engine of for exploring mod 98 4x4, I require if anyone knows about the synchronization of this engine, since I am replacing the synchronization chains, I know that they help me with a diagram, since some gears do not have marks to do this.
Thank you very much
15 years 9 months before #11800 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Sicronization 4.0 SOHC of Ford Explorer
Hello, you are not being thick is the one of 6 cyl. or the 8 -cylsome. The SOHC acronym means that it is one of a single camshaft, the model you mention sounds that its engine is four -cylinder if so you just have to put in synchronia the cranks of the crankshaft with the notch towards arriva pms and that of the tree with the arriva notch. There is no more I hope to help.
15 years 9 months before #11838 by manual-mecanica
Manual-Mecanica Response on the topic Sicronization of Motor 4.0 SOHC of Ford Explorer
The 4.0L SOHC engine for Ford Explorer 4x4 Mod 98 is 6 cylinders in V, I need help to put the engine in Synchrony, since the gears do not have marks to put it on time, since when the fault was detected, some chains were broken and the tensioners. So now you have all the pieces for their assembly, although from the beginning when we disassemble the distribution, we notice that the gears do not have a specific mark to put it on time, so I request help if anyone knows or has a diagram, or has photos that show the time put in time of said engine. I have found some diagrams but they show that the gears have marks but those I have do not bring it.
13 years 10 months before #30170 by manual-mecanica
Although I have spent a lot of time for those interested in this topic the manual of this engine is here: www.manualsdemecanica.com/manuals/manu...orer-pdf-(Sspañol)/
8 years 2 months before #52687 by manual-mecanica
Good evening I have an Explorer truck 2004 4x4 Motor 4-0 Brazilian engine presents a fault and I have not been able to find it the truck I bring it in use and melted it is already killed the pump replacement The pump filter The gasoline filter spark plug I do not know how much pressure you must maintain the pressure of the pump or that I have to regret I thank you for the support thanks in advance greetings.
