Cargo circuit problem in Citroen Xsara
15 years 6 months before #12507 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with load circuit in Citroen Xsara
You should verify that the exitation signal reaches the alternator, if you do not reach a voltage, check the fuses, we usually forget the basic things. If everything is ok, the exitation cable is cut.
greetings!!!!!!!!!B)
