Urgent I think they deceive me in the workshop
15 years 6 months before - 15 years 6 months before #12759 by manual-mecanica
Lobo1xp wrote:
Well
the truth is .. that .. if a turbo works .. without oil is spoiled. Be kma .. in less than a minute.
The other is that .. do not take any mechanic. Your car man ... sees a trusted one .. trust .. is what is worth sometimes more than the price.
The damage is already echo ... take domes. For you buy another turbo of the hinger of the fault repair.
:) According to I understand the turbo oil gallery is in the main galleries in the bloc this wants to say that after you are without lubrication in the crankshaft, piston, cylinder cover (butt "I think") the turbo is left without lubrication : UNSURE: But tell me that you walked 3 minutes accelerating thoroughly without oil, it would tell you that the engine is no more because it is already a fact that it has no hoops, bearings, turbo, etc.
I say this because I spent a turbodiesel engine it seemed that towards fumigations with the truck because it threw a very thick white smoke (only when the turbo took its peak. When disconnecting that hose and put it that falls down (it is disconnected) and cover the admission stretch the engine without problems 40,000km more. Greetings do not change the turbo since it will be an expense to the vice. Changing a turbo that does not need to be changed or spending more money and what costs a turbo gets more or less to make the vehicle engine in question.
What happens is that the oil pressure witness light turns off with just a slight press injectors). To avoid this, specific devices come to verify the work pressure of the oil by which if it varies more than a certain time for the engine and you avoid this type of breakage that are expensive, a advice puts a 20W50 oil with a maximum compression additive since the engine is to repair in the pimples 50,000km
Last edition: 15 years 6 months before by .
