Urgent I think they deceive me in the workshop
15 years 8 months before #11646 by manual-mecanica
The oil light was turned on and I stopped the car to throw it away from a carafe in the trunk but I realized that it came out without moving it called the crane to take it to the workshop they charged me 225 euros for changing the carter that was cracked the oil and the workforce. When I was going to take it when the car started to make a strange noise when I threw a lot To seven hundred, but let it upload it to the elevator I look at it then I call you. Another of the mechanics known mine, I went to school to look for my son along the way that if it could have been for having had the car without oil so that the turbo had broken down he told me that it was impossible for the turbo to only spoil for the use that it was bad luck that had had because that had nothing to do with the fault for which he had left the car in a pprincipio. This morning I called the workshop and the other mechanic has told me that the turbo has gripped for having run out of oil that the little space that goes on until the light was turned on had broken it that rained that I told him that he had not walked with him. According to them they had the car torn when the carter changed to have lost oil for another site and had not failed. If the turbo breaks me as he says why they do not fail, they have told me that if they change and carter they shut up oil in the turbo that is what has broken it. I only know that taking away that it lost oil the car the rest was fine, and just start in the work workshop failed. The mechanic has also told me that without turbo the car does not do that if it is throwing a lot of smoke, so the Civil Guard would fine me that surely it is about a thousand euros that knows that now I do not void to have that money but that I have to do it because the car so cannot walk. It is true everything they have told me or they have broken it to me and do not want to tell me. For2ue if I break me as they do not fail them. Please answer quickly.
15 years 8 months before #11647 by manual-mecanica
Hello friend, I think they have spoiled it in the workshop and do not want to recognize it, fight it to death because they must recognize their mistake, a hug. :)
15 years 8 months before #11652 by manual-mecanica
Having spliced ​​to you, the turbo when it is reacted most of the time it is due to lack of oil, it is not necessary that it even 5 minutes and it has already bothering you, I tell you why it has happened to me with a motor that new mount and defective wine, with the greedy gulf hose that according to the car model it can go to the carter but even if the oil was thrown out there, the turbo would not be spoiled. It may be that it is broken by some other thing - but it was a coincidence that it has been in the workshop. They do not deceive you and I tell you that I am a mechanic but I do not work in any workshop but in the maintenance of a company.
15 years 8 months before #11653 by manual-mecanica
It seems to me that when it is answered as a minimum one must give an argument unless you expect a conflict between this man and the workshop
15 years 8 months before #11659 by manual-mecanica
The on the only way that the turbo spoils is due to lack of oil if, the light turned on it is because you had nothing or very little, if this is the case then the mechanics have nothing to do with the breakdown of the turbo, in addition if your vehicle is not equipped with a turvo Taimer it was only a time of time for it to spoil, the Turvo Jira to many rpm many more than the engine and its structure is very delicate Agripan or cut, it has nothing to do with a mechanic to change your carter and spoil it, there are many visions on this subject, that they changed it for another and things like that, I do not think it is a problem of the mechanic or for a bad morning, it was only bad luck and nothing more, now you can walk without turbo, but you will That is likely that as it is assumed that smoke is oil in the exhaust only verifies that the main escape and that is what they have to be checked.
