Meriva problems put on time
15 years 8 months before #11644 by manual-mecanica
Meriva problems put in time published by Manual-Mecanica
Hello, I have problems with a 2008 meriva, its engine has a double camshaft, tube a heating and it was necessary to change the head packaging, when the engine heads down, its revolutions do not pass from 700 and when the machine is accelerated, but when lowering speed does not go out but the engine begins to head, they tell me that it is out of time, they would hate me. Thank you
15 years 8 months before #11658 by manual-mecanica
Manual-Mecanica response on the Re: Meriva problems put on time
How do we help you? What do you need? If the full data of the car, displacement, model year and that is worth it.
15 years 8 months before #11663 by manual-mecanica
If what my good kikemec says, depending on the country, it can be the IAC valve or the acceleration body does not handle Chicote pa accelerate is an electronic tps with a sensor on the pedal, for not the big story is reprogrammed by the idle with a scam greetings.
