Problems with my car
15 years 8 months before #11641 by manual-mecanica
Problems with my car posted by Manual-Mecanica
Good afternoon I have a toyota corolla injected motor 4a 1600 cc
the engine had a tronid as valves caliber the valves and the sound continued the compressions they had 170 in cylinder one and two 175 in cylinder 3 and 160 in cylinder 4 one day the curate packaging and tube that opens it takes it to the rectifier we saw. From bank and rod and new rings we put together the engine but the sound of continuous valves.
There is someone who can help me
15 years 8 months before #11643 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with my car
Good afternoon I have a Peugeo 307 Model Hagoneta 2005 ... The problem is the transmission is Citronic the mechanic tells me that it is electrical fault and the electric indicates that it is mechanical failure some could support me to obtain the transmission manual of this vehicle ... to know more thoroughly the transmission and they are not lying to me by the mechanics .....
there is someone who can help me [/quote]
15 years 8 months before #11726 by manual-mecanica
Greetings Friend, I suspect that you suddenly took into account the blocking of the camshaft pinion that has a system that minimizes the sound between the two pine nuts, so that you understand me better it is the one that seems to have two pine nuts, within these there is a spring, you must turn a part of the pinion against the other until they coins some gaps where an 8m tormillo is put in the 8m tormillo when it Before disassembling it, now - if this is the case - you would disassemble the camshaft and do the procedure I told you before. I hope I have helped you .... Please tell me how reparation is doing. thank you.
