VW GOL 2000 VIBRA DIRECTION EVEN IN LOW SPEED
15 years 10 months before #11582 by manual-mecanica
VW GOL 2000 VIBRA DIRECTION EVEN IN LOW SPEED PUBLISHED BY MANUAL-MECANICA
, Hi Gentita, here with an uncertainty
over
time began to accentu Days, I turn on the car, I put first, second and the steering wheel began to move alone, fill the front tires with air and be attenuated a little, then the pressure calibrates and the problem became much more notorious, at 10km/hra the steering wheel as I said moved from one side to the other what is the cause of this vibration of the steering wheel, it is a problem with the direction right) or maybe have problems with the label or terminal, some talk about the mockery
appreciation of their gentle comment
15 years 10 months before #11617 by manual-mecanica
Manual-Mecanica Response on the Re: VW Gol 2000 Vibra Address even in low speed
Friend, the best thing you can do is lift the wheel and move the wheel vertically and orioly the movement will have to be null or very minimal, that is a classic failure in the address, terminals and accials, the sink is another topic will have to check the bearings and the rotation influences the direction tending to pull the vehicle on one side since VW has a Chinese loop. I would recommend checking what I tell you and if everything is fine aligns the vehicle is the only solution
15 years 10 months before #11623 by manual-mecanica
Hello friend, in Mexico when a vehicle has that problem, it is generally due to the wheels or wheels of the tires that have twisting, it can also be due to damage to the tire's bearing surfaces, this is usually due to damage caused by poor condition of the road, here we suffer a lot with what we call stops and potholes.
15 years 9 months before #12140 by manual-mecanica
Good: Vibrations can be due to several causes.
Bearings in poor condition.
imbalance in the wheels for the use or change of position.
And I think that low -speed vibrations with a slight noise when you turn to the side can be the cardan axis that sends the transmission to the wheel.
I hope it serves you something.:)
15 years 9 months before #12149 by manual-mecanica
I appreciate your comments, only an additional consultation, in relation to the cardan, to your poor condition, it has something to do with the fact that you change your palieres (due to poncho wear)
