The engine not for
15 years 8 months before #11518 by manual-mecanica
The engine not for Manual -Mecanica
Quito the contact key and the engine is still running my car is a Renault Clio of 93 1.9d
15 years 8 months before #11519 by manual-mecanica
Manual-mecanica response on the re: the engine not for
The bombin will be broken
15 years 8 months before #11540 by manual-mecanica
If it is diesel it may be that you have a lot
15 years 8 months before #11729 by manual-mecanica
Change the even valve that is on top of the injection pump, if the starter wrench has no code is easy task, if it has code it is a bit more complex because it has a protection sheet that is screwed with auto breakwoods.
