"Urgent accident with straw or montero"
15 years 9 months before #11494 by manual-mecanica
"Urgent accident with straw or montero" published by Manual-Mecanica
Hello friends
I had a very big problem with a Mitsubishi Pajero or Montero 2001 of Second Generation Motor 2.8 Diesel without turbo. 4m40 description engine, this car is five doors, this weekend that passed my mother led the car and had a very serious accident with it, she was hospitalized and thank God it is already out of danger, I hope that the help they provide me serves many people who can in the future face this type of problem. She tells me what happened like this:
He says he was conducting the vehicle for a slope of not much inclination of about 2 km away. She wore the car at fourth speed and without pressing the accelerator led to 60 km / h. When suddenly I listen to a large noise in the engine I deduce is the increase in the revolutions of the same and the car is accelerated only at an impressive speed to such a degree that the brake was not served from anything. At the end of this street there was a semaphor with many cars. whereby she desidated to climb on a slope before reaching the semaforo and collided with some advertisements. The car stopped by colliding acting its air bags.
I must try to repair the car and I have many doubts.
1. Since this can be repeated. That this problem could be due in the car or what the points to investigate that they could generate this problem would be. assuming that he had been with good maintenance.
2. When giving a problem like this. That the driver can do to stop the car.
3. What type of preventive maintenance can be carried out to avoid this type of problem.
Thank you very much in advance for your support ...
Greetings
15 years 8 months before #11531 by manual-mecanica
Manual-Mecanica response on the Re: "urgent accident with straw or montero"
Hi Alex, first of all, tell you that I am happy that your mother is well, what you tell us and accounts is a bit difficult to educational without looking at the vehicle and seeing what damage was the one that caused the fault, the first thing I would like to ask you how to eat to deduce a possible cause, it is that you check the distribution strap, it is the first thing that the noise that was heard is the cut of the belt, and therefore the vehicle It was, it may also be damaged by the motor brake, which I am not very clear is whether your vehicle is equipped with this type of device, check and tell us.
15 years 8 months before #11548 by manual-mecanica
Look that, I was checking the car, and I could light it without problems I did not look at; I mechanics in any of the pieces, I could only observe a strong blow to the chassis I think that a half inch should have moved, this worries me even more because I do not deduce the cause of the accident and I am afraid that this can be repeated, someone mentioned something about the governor of the injection pump, but I do not even Support, I hope you can keep guiding me.
Greetings
15 years 8 months before #11560 by manual-mecanica
Czech if the marches enter because the noise is the one we must stood, to see why he went suddenly
15 years 8 months before #11593 by manual-mecanica
The cable or accelerator sensor can be caught, because that of the belt ... if it breaks stop walking instantly. What can also have broken the turbo and when passing a lot of oil to the cylinders accelerate alone.
