Problem in Clio 1.2 of 2002
15 years 9 months before #11489 by manual-mecanica
Problem in Clio 1.2 of 2002 published by Manual-Mecanica
Hello very good, my consultation is that I have a CLIO 1.2 of gasoline in 2002 and it gives me problems to start it in cold I can throw up to 2 minutes until it starts it and in the end I finish it starting it and then it goes perfect until the next day I will start it and again the same thing, if someone I thank you for the help, thank you very much for your help in advance.
15 years 8 months before #11530 by manual-mecanica
Manual-Mecanica Response on the Re: Problem in Clio 1.2 of 2002
These types of problems are classic of the Checalo and notan temperature sensor,
15 years 8 months before #11597 by manual-mecanica
Hello, if when the car is torn off as three cylinders, change the high and solved coils, a greeting.
