Any problem with a vehicle?
15 years 6 months before #12920 by manual-mecanica
Manual-Mecanica response on the Re: Tines any problem with a vehicle?
wave!! I had a problem with my alpha 156 1.9 JTD of 99.
I conducted so quiet when the clutch began to be loose,
the marches came in but it was forced a Poko.
Well, purge the clutch and change the bombin, now, the pedal has recovered its normal tension, but it does not disengage and it does not enter one march ...
If someone has occurred any similar case and save where the cause can be, to help me xfavor ... the workshop manual also serves me, but I can not find it complete ...
and I would disassemble engine or not ...)
thanks to all those who show interest in helping in this forum ...
The theme has been closed.
15 years 6 months before #12921 by manual-mecanica
Surely you have the normal tension on the pedal, I would say that you have to change the pump not the bombin and purge it well
15 years 6 months before #12956 by manual-mecanica
Manual-Mecanica Response On the Re: Nest
Brother Can I tell you that car is a Siena HL 1.6 sp This helps something?
15 years 6 months before #12957 by manual-mecanica
Brother I forgot to tell you the car is gasoline but I would not know if it is turbo I reiterate what is siena hl 1.6 sp if you can send me some photos for me to identify the brands of the belt and that of the pulleys I thank you for brother thanks
15 years 6 months before #12958 by manual-mecanica
sorry, I had OLBIDAO say that the bomb also changed!
The problem persists!
I appreciate tola
