Any problem with a vehicle?
15 years 8 months before #11766 by manual-mecanica
Manual-Mecanica response on the Re: Tines any problem with a vehicle?
Hello, how about, I have a problem not very serious but I would like to solve it, I have a 90 Sierra from GMC in Mexico, it is from an automatic 4x4 with a 5.7 l engine, the problem is that the 4x4 worked well and turns on the base of the change lever a light that indicated that this active I stop doing it when I active the 4h and does not enter the 4x4 but if I put it in 4l Net the focus I hope and you can help me greetings
The theme has been closed.
15 years 8 months before #11768 by manual-mecanica
You do not indicate if they checked the alternator, normally the battery receives load from this component when the engine is working.
15 years 8 months before #11773 by manual-mecanica
Manual-Mecanica Response on the subject Re: Reaprete Culata
Hi: First I want to greet you, it's my first contact with you. From Concepciòn Chile, I greet you, the question is as follows: what are the measures if so they are said to reappriev
15 years 8 months before #11783 by manual-mecanica
How, for the head torque I recommend that you visit automecanico.com you will find relevant information, it is a page designed for mechanics I like, and I recommend it health2
15 years 8 months before #11784 by manual-mecanica
Look would have to check first the electrical circuit of the 4x4 indicator, check the Transfer seeks information on the automecanico.com page If there are doubts to tell me health2
