Any problem with a vehicle?
15 years 8 months before #11629 by manual-mecanica
Manual-Mecanica response on the Re: Tines any problem with a vehicle?
Excuse me that I cannot help you, I do not have that information, the diesel vehicles is very scarce, the information is very scarce, we must exort to the classmates who have it to distribute it to be able to make a better union and exchange experiences
The theme has been closed.
15 years 8 months before #11631 by manual-mecanica
First of all, good to all and congratulations for this page of page.
It has been very helpful with my Nissan Almera Reestyling `04.
But my problem is as follows.
My father has a Renault Express gasoline without a/c, (forgive but I don't know what model it is, tomorrow I specify it) and went to pass the ITV and they told him that he has the cracked overalls and the caps of the direction bar gone and my problem is that I do not find information about it.
I, in my Almera every time I break something I fix it, I also download the Almera Workshop Manual from here, but only the Motor Manual and Gear Cash. Then I wanted to ask you if you can guide me a little on the subject to fix it, since I think it doesn't have much difficulty.
Well, that I roll up, if you need any more data or any questions ask me, ok?
Hopefully you can help me, I trust yes, I wait for your answer.
Thank you for having heard at least and thanks for everything.;)
15 years 8 months before #11639 by manual-mecanica
Hello I hope you can help me with a Seat Ibiza 2004 1.6 liters The preoclema is with the closing of doors with the key at the active door and deactivates alarm, but with the control no. The batteries were changed to the control and code with a CJ4 indicates that the procedure is done but the control is still not working or where I can get the workshop manual to check lines and voltages
for your attention thousand thanks a thousand thanks
15 years 8 months before #11681 by manual-mecanica
That before anything you must check that if the unit has manual glass you should enter the comfort group, if you have electric glass at a summons closure, extract codes to see what code marks, or in your first case you must give you the controls and then with the CJ4 you must configure them, and how many are you going to program, do you have activated the program in the CJ4?
15 years 8 months before #11684 by manual-mecanica
Sub-marca PAIS
YEAR TYPE OF INJECTION
MOTOR
TRANSMISSION T/M O T/A
If it has air conditioning
if it is 4x4
Failure symptoms
that have made
DTC found
Dodge Atos India
2007
1.1
t/m
without a a/c
dick a little when starting and changing to 2a. And when the car is loaded when asking for power responds with failure as if they were the current cables but if not, it does not fail.
I already changed the cables and remains exactly the same, if I start fast it does not fail until I put the 3rd. I just feel a little slow in normal handling.
He throws the problem code in detonation sensor but I have not found it more than in the agency and comes out in more than $ 1,000.00, do you know somewhere to find it and get cheaper to do the test?
