Flagge Nissan Patrol V8 problem
15 years 9 months before #11420 by manual-mecanica
Flagge Nissan Patrol V8 problem published by Manual-Mecanica
Well. This is the thing I have a Nissan Patrol GR 1982 with a V8 Chevy 350 Small Block. With all the original Nissan hydraulic clutch set of 4.0 online and a "Nissan Patrol Diesel" box of short relationship.
I carry with this "set" engine, box and smell 3 years and had never presented recent problems after engine settings. It happens that with the clutch stomped thoroughly it costs a lot than among the first march! And after a while of shooting like 2 - 3 hours the problem is passed to the other marches.
Any suggestion ??????
15 years 9 months before #11441 by manual-mecanica
Manual-Mecanica Response on the Re: Problem of Flagge Nissan Patrol V8
If you are not sliding it can be the graduation of the lapiz ..... verify it ...
15 years 9 months before #11442 by manual-mecanica
Friend for being an adaptation as a common in difficult to help you a lot of you can with the graduation if you have it, grena the air that the system can have, if it can
15 years 8 months before #11528 by manual-mecanica
I would discard the pedal and adjustment since the hydraulic clutches have no adjustment, as I see the problem is the kit installed, so you say the box that is from another vehicle, it seems to me that the disc burns you, but the problem is the wear of the disc, or the other that the range of the press is very closed
15 years 8 months before #11529 by manual-mecanica
Thank you very much `pr contributions ... buneo a. final opt for the healthy .. change all press disc pump!
And now all good !! ..
Thank you very much for the collaboration!
