Terrano motor arrangement at home
15 years 5 months before #11391 by manual-mecanica
HOME TERNORANO MOTOR ARRANGEMENT PUBLISHED BY MANUAL-MECANICA
Hello Foros, this is an "adventure" that I have undertaken alone .... I have a terrainii (100cv) with a burst cylinder and I decided to fix it with the few tools that I have at home hehe I have disassembled everything of the engine (button, alternator, air compressor, straps ...) less diesel pump. I released the Emprague and those of the Silentblock Peeeeeero when I am going to remove the engine, what is inside the clutch housing comes with the engine !!!!!!!!!!
to release the clutch engine? Greetings
15 years 5 months before #11395 by manual-mecanica
Manual-Mecanica response on the Re: Terrano motor arrangement at home
I will look for the Nissan Terrano workshop manual and I send it to you
15 years 5 months before #11396 by manual-mecanica
What a uncle, I have the manual but it does not explain it well .... hehejjee is the same, I will try to disassemble everything Jojojo thanks
15 years 5 months before #11397 by manual-mecanica
To get the engine you also have to remove the box
15 years 5 months before #11398 by manual-mecanica
Valla, it's what I fear ....... The box and clutch don't give much problem?
