Doubt Mitsubishi Pajero or Montero
15 years 9 months before #11378 by manual-mecanica
Doubt Mitsubishi Pajero or Montero published by Manual-Mecanica
Hello friends
, I am new in the forum and I would like to know Sialguien with more experience can help me, I have a mesubishi straw or montero diesel that the consequence sold as 2001, has a Diesel engine 2.8 without turbo and it is the work version (manual glass etc.), I also look that the back of the back is a little taller than the others that I have seen, with respect to this vehicle I have two doubts
. 2001 when it is more similar to those of the second generation or that of the 1998 model only than with a higher roof ..sess this other version of the straw or will have continued to draw old models along with the newest models someone knows something of this model in particular?
2. Everything with the car is going well, only that in the ma; Ana is a bit hard to teach after the whole day is normal, check with a mechanic engine and pump compressions and apparently everything is fine, change the oil and put Castrol for diesel for recommendation of the mechanic, but apparently everything remains the same. In the ma; Ana to teach it the shock button to increase the motor revolutions a bit this normal practice and of common use in the vehicle or this button has another application and I can be causing a day; or the future to the vehicle. If so, other alternatives I can try to solve my problem.
15 years 9 months before #11386 by manual-mecanica
Manual-Mecanica Answer on the Re: Doubt Mitsubishi Pajero or Montero
See the model will depend much on the place of processing your vehicle, it is difficult for them to change the year because it is illegal, now here in Chile that case happened with Crysler that changed the codes of the chacis and sold the vehicle as 5 newer years, and the problem of boot Its position, send a direct battery current for about 5 to 10 seconds and proves if the problem is well part of the heater
15 years 9 months before #11403 by manual-mecanica
Thank you very much for the answer, apparently the heater work well, this test you mention is to turn on the car only with the battery without going through the heater ???, thank you very much very much
15 years 9 months before #11414 by manual-mecanica
Not what I mean is to send current from the positive of Vateria to the heaters for a period of 5 to 10 seconds, with this we discard the timer of the heater, it is very easy you have it and let us know
