CLEAN PROBLEM/LAMBOBRISEAS R19 TD YEAR 1991
15 years 9 months before - 15 years 9 months before #11271 by manual-mecanica
CLEAN PROBLEM/WASHER R19 TD YEAR 1991 PUBLISHED BY MANUAL-MECANICA
Hello, good morning/afternoons/nights.
In Specific I am looking for the relay that controls the front wardrobe/lava -absence (nothing works for me), they do neither noise or anything.
The command was broken several weeks ago, but I kept working, until one day I stopped working completely the clean/washer.
I have changed the control (handle) to act (the one that is to the right of the steering wheel, that is, the control to use the clean/dishwasher), and the cleaning/lava -abrab engine (which goes in the center of the capo a little hidden right in the center under the windshield wiper.)
The fuse of the "wiper timer. changed by the flashing that if it works for sure that fuse and is also 10A and remains the same)
the box of relays I have also located it and it seems that there is none burned, or poorly connected.
Are they in the fuse box? (Under the glove compartment) or there are more relays (I have also looked in a black box under the capo, on the right side, which has a lot of cables and "boxes", they do not seem badly).
Any other idea where the problem can be?
The cables seem to be fine. But I don't have an appearance of those to measure electrical tensions and others.
Thanks and Salu2.
Last edition: 15 years 9 months before by .
