Front vibration at a certain speed
15 years 7 months before #11254 by manual-mecanica
Front vibration at a certain speed published by manual-mecanica
Hello friends ..
I go back to your help, after consulting them:
with a Fiat Siena 98, in an approximate speed range of between 70 and 90km/hr (4th speed) you feel a vibration in a lateral way, that is, from side to side on the front of the vehicle. It can be seen with greater force when it is heavy, that is, with full passengers. When handling it, it is not so much appreciated. Outside this rank this vibration is not presented.
I would like to know which would be the possible causes of this vibration ..
thanks for your help !!
Greetings!!!
15 years 7 months before #11263 by manual-mecanica
Manual-Mecanica response on the re: front vibration at a speed
Hello ... in what state are the rubbers and the wheels ...
15 years 7 months before #11267 by manual-mecanica
Probably lack of balance. Didn't you crash the sidewalk recently or did you fall into a pothole?
15 years 7 months before #11269 by manual-mecanica
I think the same with a swinging that vibration of the disappearing, pro if the vibration is lateral that is to say it moves to the sides can be because of the alignment or by poor condition of axial terminal terminals of direction or label
15 years 7 months before #11276 by manual-mecanica
Hello friend, as the classmates say well the balancing and the state of label and ends of address, luck and greetings. :)
