Distribution belt change
15 years 10 months before #11209 by manual-mecanica
Distribution Correa Change Published by Manual-Mecanica
Hello.
I want to change the distribution strap of my Renault Kangoo Motor F8Q 1.9.
Can anyone guide me how to do it?
Thanks in advance to any answer.
15 years 10 months before #11215 by manual-mecanica
Manual-Mecanica Response on the Re: Change of distribution strap
Hojo with the change friend distribution of this vehicle has many details by committing for the tools, you have to use special tools to penetrate the distribution of this vehicle, if you do not have them, not you will be cheaper and cencillo send it.
15 years 10 months before #11231 by manual-mecanica
I thank you for the Kikemec Council, I know it's a bit complicated, but I want
to learn how to do it, I like mechanics.
15 years 10 months before #11245 by manual-mecanica
It is not because I do not want your friend to be entered, it happens that for example the Renaul Clio II and other Renaul models do not have a key in the dentate gear of the crankshaft, so you have to buy the kit for the draft that costs a little expensive, peri if you want to do it your steps are the following, I do not recommend in this vehicle. haha. Saches the strap strap the tapas that cover the distribution, tranca the steering wheel and release the Damper pulley takes out the engine support so you can enter, release the tensioner Maarca all the belt and its position with respect to the Sigual and the cams before doing so, and take out the belt. Good luck amio
15 years 10 months before #11251 by manual-mecanica
HELLO . Kikemec.
Again I appreciate the advice and the help you write to me.
Surely it will be very helpful.
