Motor Witness in Opel Vectra
15 years 9 months before #11200 by manual-mecanica
Motor Witness in Opel Vectra published by Manual-Mecanica
Hi, there has been everyone if you can help me, I have an Opel Vectra GT is one of the first models
because suddenly the light of Check Engine was turned on and I don't know what the fault is because the car does not make any symptoms of going wrong.
greetings
15 years 9 months before #11213 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Witness in Opel Vectra
The easiest way is to scan the car, you just change what is really wrong, since there are many components that light the light, now it is usually devided to the oxygen or temperature sensor.
15 years 9 months before #11216 by manual-mecanica
The diagnosis machine has already passed him and fails, and wanted to eliminate possible failures
that the machine does not detect
15 years 9 months before #11218 by manual-mecanica
The only way that check is caught and that there are no failures is because of an electrical problem that activates the light, but this happens very little is very rare, you want the diagnosis I did not recognize the system you could put another one elsewhere for surely for sure if you want. It's what I wake up
15 years 9 months before #11226 by manual-mecanica
This is what we will try in another workshop if there is luck and detects the failure
greetings
