Help with a 2002 Ford Ka, problems on
15 years 9 months before #11188 by manual-mecanica
Hello everyone, I have a problem with my car, it is a 2002 Ford Ka, when I ignite it and I have to accelerate it and since it ignites if it stops accelerating it, this can do it several times before getting it correctly and on it does not turn on again.
I hope someone can guide me about what problem they can have so that they do not see my face in the workshop: blush:
thanks and greetings to all
15 years 9 months before #11211 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with a 2002 Ford Ka, Turning Problems
Czech the temperature sensor and the Relay Regulation Valve
15 years 9 months before #11221 by manual-mecanica
If the fault does it only when starting it in cold it can be the ECT sensor, it is temperature, once it reaches a certain temperature it works normally. The one that is extinguished when it ceases to accelerate can be the byp valve, it is slowing down and incidentally checking the TP sensor, it may be failing and the computer does not relate the amount of fuel it needs for a low temperature. I hope it helps you, greetings, bye.
15 years 9 months before - 15 years 9 months before #11261 by manual-mecanica
Thank you very much for your help.
Greetings
Last edition: 15 years 9 months before by .
15 years 9 months before #11262 by manual-mecanica
Hello ... some questions when I get on the light of Chek, what km has, what services I take to the car
