Problem with a Daewoo Racer
15 years 9 months before #11127 by manual-mecanica
Problem with a Daewoo Racer published by Manual-Mecanica
Hello Friends of Mechanica Manuals please I need a little help with this topic I have a Daewoo Recer year 94 I made a semi adjustment I change rings, metals, culatin, cam Frio does not happen please if they know what goodbye can be and happy new year :lol:
15 years 9 months before #11129 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with a Daewoo Racer
HAPPY FRIEND YEAR FOR YOU ALSO. I am from Venezuela and I do not understand very well the name that you give to the pieces, that problems is typical in the cars that have that engine (lanus, sky, corsa, etc.) is what they call oil or silk collector that is nothing more that it had to go from the oil pump to the bottom of the carter and that is by where the pump absorbs the oil, in the stretch it carries a mesh filter covered with a species of cup is surely covered. It takes its time to clean it but you have to do it very well I recommend you use acid for engines. Do it and tell me.
15 years 9 months before #11148 by manual-mecanica
Jrosacol is right The problem is the same and the taquis noise is because the oil does not supply, draws the pacifier from the oil and clean it well Abesses is covered with the same silicone that put the carter.
