Please help in my Xsara Picasso
15 years 9 months before #11346 by manual-mecanica
Manual-Mecanica Answer on the Re: please help in my Xsara Picasso
Going to high revolutions is fine. And by city, I should be there.
15 years 9 months before #11389 by manual-mecanica
Hello again I still have consumer problem goes to 8 liters and my friend has it the same and it is going to 6.5 l. I made additive verified several things and I have reached a conclusion and I hope you can make me a little hand, in the self -destroy I have seen that the car can consume you by the flow sensor of the air mass I have removed it, I have cleaned it but it is fine, but it puts in the self -destination that the voltage of the point 5 and 6 of the connector removed that would start the car and I had to give me to give me 2 v. And accelerating briefly 4.4 v., I have caused it with the polyimetter and I do not give me any voltage, there the fault has to come I have looked at all the fuses in the car and it is fine, but I think it will be a rel but I do not know where it is, if you can make a little hand, I know that if I take it to Citroen they solve it, but I am now in stop and I can not afford. Greetings, I wait for your help.
15 years 9 months before #11457 by manual-mecanica
Forget about the relay, that the caudalimetro does not carry any rel. connected !!!
15 years 9 months before #11466 by manual-mecanica
I don't know what to do I am driving myself crazy, the car is going well but consumes a lot with the full deposit almost hurrying the deposit made 600 km. and the deposit 60 l. I have made 50% per cart and 50% per city without going very fast in Carretra at 120 km/h. and in normal town and leaves 9.5 l. According to my calculation I have looked if I lost for an injector through the oil filter and there is nothing of Gasoi the engine is clean, because the EGR valve should not be no? Because you would not walk well anyway in a forum that the valve EGR making you do not know that the car can be canceled and the car is better in consumption and in speed that you think, in the end I will have to spend the pasta and take it to the house CITORN, thanks and greetings.
15 years 9 months before #11467 by manual-mecanica
Well, take out injectors and take them to check, because there is no additive to clean you that type of injectors. They are easy and fast. In some bosch they will do it but ask in any workshop where you can take them
