Ford explore 93
15 years 9 months before #11173 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Explore 93
By chance you do not have the manual of this van in Spanish please I would appreciate it very much and beforehand thank you.
15 years 9 months before #11222 by manual-mecanica
As you have told you, you must check first that there are no suegueras of empty, that makes you spend gasoline. That all cables and spark plugs work well. Check the ECT sensor, the gasoline pressure regulator, the MAF or MAP. The Hego sensor can fail, but it is weird, it is a reflection of the fault.
Greetings, Bye.
