Motor failures DT466E HINTERNACIOAL
15 years 6 months before #11039 by manual-mecanica
DT466E Hinternioal Motor Faults published by Manual-Mecanica
Good morning friends I have a truck with a motordt466e with a failure turns on very well but when you arrive at 1200RP stop accelerating and it is left on it, the acceleration sensor is changed and I do not improve if anyone knows thank you
15 years 5 months before #11372 by manual-mecanica
Manual-Mecanica response on the re: motor failures DT466E hinternioal
Try to disconnect the computer so that the data you have stored are deleted.
15 years 5 months before #11383 by manual-mecanica
I think the same when the data is stored, they are bad, now the Levante valve and notice that they do not help it from revolutions
14 years 11 months before #14381 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Failures DT466E International
Look at the best was not the straight pedal since the vin of the Veículo changes I recommend that checks with another pedal and put a 1200 homs carbon resistance in the letter D of the pedal
to lower the amperage of Validation of Relay that is most likely. I also recommend checking the throttle pedal fuse.
14 years 7 months before #17205 by manual-mecanica
Heyo I also have the same problem. It would be very much to ask you to comment as you solved the failure. Thank you in advance.
