Chrysler Neon 1998
15 years 10 months before #11022 by manual-mecanica
Chrysler Neon 1998 published by Manual-Mecanica
Hello everyone, very good afternoon I need to know if someone can tell me how to try the neon PMS sensor since I have one and it has no spark and therefore it does not start I think that is that or if someone had a similar problem tell me that something else can be, thank you very much I hope you can help me good afternoon
15 years 10 months before #11026 by manual-mecanica
Manual-Mecanica Answer on the Re: Chrysler Neon 1998
If it is 2 pin, see if you have continuity, and see if it changes approaches and Alejandol to metal. If it is not so ... change it
15 years 10 months before #11034 by manual-mecanica
The PMS sensor? or the crankshaft position sensor. If this measures the resistance to be between 500 and 800 kilohoms, then the other PAST PASA METALLICO Ahead and see if it sends a sign
15 years 10 months before #11035 by manual-mecanica
Thank you very much for the data anyway this sensor is three cables anyway thank you very much
15 years 10 months before #11036 by manual-mecanica
Two of those three cables have to have a resistance of 500 to 800 OHMS, and Czech that the Earth cable does not have more than one OHMS with respect to the motor of the motor not the battery, then a metallic element passes ahead of the sensor and Czech that with the QUUE cable did not measure and the Earth sends a voltage signal.
