Rear Clean in Renault 19 TD
15 years 11 months before #11004 by manual-mecanica
Rear wiper for Renault 19 TD. Posted by manual-mecanica
The rear windshield wiper only works the first time I turn it on, and only once. After that, it stops working. I've cleaned the switch with compressed air in case it had carbon buildup, and the connections are fine. What could it be? A relay? Where are the relays located, and which one is it?
15 years 11 months before #11015 by manual-mecanica
Manual-mechanics' response on the topic Re: Rear wiper on Renault 19 TD
The relays are located in the same fuse box or at the front near the motor. This relay is usually in the fuse holder. It could also be that the motor's contacts are worn. Remove the top cover and check if the points or contact channels are worn. Alternatively, you could try another motor and test it. You can also check for continuous current flow at the connector.
15 years 11 months before #11018 by manual-mecanica
The relays are in the fuse box, but which one is for the rear wiper?
15 years 11 months before #11020 by manual-mecanica
You should have a sticker that tells you which one it is, or activate the wiper and listen to where the relay activation noise is coming from, or test if there is power at the back, at the motor connector.
15 years 11 months before #11038 by manual-mecanica
Bridge the wiper relay, remove it, and connect pins 30 and 87 with a wire. If it works continuously without any issues, the problem isn't in the motor or any wire from the relay to the wiper. Start there for now.
