Chrysler Vogayer LE 98 BLOCK LE 98
15 years 10 months before #10976 by manual-mecanica
BLOCK CHRYSLER VOGAYER LE 98 PUBLISHED BY MANUAL-MECANICA
Hello everyone,
I am new in these forums, I have a Chrysler Voyager Le 2.4 16V of 98, and in recent days the start is blocked, that is, I introduce the key to the contact and does not turn to give contact.
Does anyone know what the problem can be?
Thanks in advance
Jose
15 years 10 months before #10982 by manual-mecanica
Manual-Mecanica Response on the Re: Blrysler Vogayer LE 98 Start block
That is a friendly sheet problem usually happens, you have to take it to a chapero or failing to buy the sheet and install it yourself.
15 years 10 months before #10984 by manual-mecanica
I just understood the answer, do you mean the sheet that is seen around the key of the key?
Thanks
Jose
15 years 10 months before #11019 by manual-mecanica
Check if you get out of the start to the start of the cable that comes from the key after you go to the rest it is automatic the change or manual, if it is automatic, try to put it in the dead or in neutral to see if it goes, if you arrive current it can be the start
greetings
15 years 10 months before #11025 by manual-mecanica
Simply change the bombin, unless the key is worn, carries the bombin with the key somewhere that make you a new bombin for that key.
