307 SW does not go from 2500 rpm
15 years 10 months before #10939 by manual-mecanica
307 SW does not go from 2500 rpm posted by Manual-Mecanica
Hello, I hope you can solve the problem my 307 SW does not pass from 2500 rpm, it comes out on the screen I fail in the antipolution system Take measures and remove the filter partulas and the hole was clean perfectly even put air and passed without problems. Buelta because 500 in total and nothing I hope you can there to forgive me for spelling, I am not very good for me
15 years 10 months before #10948 by manual-mecanica
Manual-Mecanica response on the Re: 307 SW theme does not exceed 2500 rpm
Try to disconnect the flow and try it, if it works well, it is because that piece is bad.
greetings.:)
15 years 9 months before - 15 years 9 months before #11106 by manual-mecanica
It seems to me that what happens to your 307! Your 307 how many kilometers you have, wait, don't tell me, more or less 100,000. The engine will be a 2.0 HDI of 110 hp, right ?? Well what was going on these engines that break the antiparticle filter (FAP) at 100,000 km !!
Surely replacing the FAP would pass from 2500 rpm (although there is no force to high revolutions in these engines ...: P )
Last edition: 15 years 9 months before by .
15 years 9 months before #11315 by manual-mecanica
: UNSURE: Check that the escape is not obstructed sule present yourself in that way
with trying, do not lose anything greetings and luck
15 years 9 months before #11332 by manual-mecanica
I think just like Jonan, but you can check the state of Catalan anyway when they cover do not pass 2500 and there are less check it than is not covered.
