Posterior noise in Honda CRV
16 years 4 weeks before #10873 by manual-mecanica
Rear noise in Honda CRV. Posted by manual-mecanica
For some time now, I've had a noise coming from the rear of my '99 CRV, and I can't figure out what's causing it. The mechanic removed the axles to turn the wheels on the lift, but they couldn't confirm if any bearings were faulty, and the noise persists. Any suggestions?
16 years 4 weeks before #10877 by manual-mecanica
Manual-mechanics response on the topic Re: Rear noise in Honda CRV
It would be helpful if you could describe the noise: whether it occurs at high or low speeds, or with the engine off when turning, and if there are any vibrations or anything like that. More details, please.
16 years 3 weeks before #10886 by manual-mecanica
Thanks Kikemec, it's the typical noise of a bearing, but unlike that, it doesn't get louder when rotating and there are no vibrations, nor does it change whether the engine is running or off. It sounds like the typical rolling noise of tires, and that's ruled out because we changed them a few days ago.
16 years 3 weeks before #10891 by manual-mecanica
But the noise only appears when moving; it doesn't happen when idling?
16 years 3 weeks before #10894 by manual-mecanica
Correct, with the moving vehicle is when listening.
