Toyota 2L-T diesel pump
15 years 10 months before - 15 years 10 months before #10844 by manual-mecanica
Gasail Toyota 2L-T pump published by Manual-Mecanica
Hello, the car is a 97 Toyota Hiace, 2L-T motor type, scope 2.4 Diesel, the injection pump mark is dense and is rotating.
I explain, a partner my name to mounting this type of pump, which happens, that the toothed pulley that goes in the distribution has no mark and I have to peel the pump with the distribution.
Latest edition: 15 years 10 months before by .
15 years 10 months before #10846 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota 2L-T diesel pump
I do not understand what you mean by Victor, tell me that Toyota you speak, and if it is benzinero the fuel pump does not carry position, give me more data of the car to be able to help you, model, year, displacement, fuel and that, so we can help you better.
15 years 10 months before #10884 by manual-mecanica
All the toyotas, have two marks in the pumps of that year, look at the pump from front to you, a small line has on the right side by the side, where the eyelet is, and in the motor hous The twelve less, there it would start without problems, we in the workshop after this we put a comparator in the rear and we remembered the remembered that marks the autodata, this if it is complicated and the special tool is missing.
15 years 10 months before #10885 by manual-mecanica
There is a 2L-T model that the pulley carries a sheet with three screws that only enter a single position that has to be there, there carries the march, a stripe on the sheet, which serves not to not get the strap
15 years 10 months before #10890 by manual-mecanica
The pump pulley if it brings a mark, in one of its teeth checked well, the crankshaft pulley and cams have marks and you have to put it in front of the pump, the pump is in ninety degrees looking straight ahead is straight towards Arriva, if you want the scheme send me a message with your email and send it to you, it is in car data if you want it.
